Restoration & Repair Tips Board
2000 ford stering
ron ingram
06-12-2005 09:14:16
my 2000 ford has started leaking around the worm gears on the stering gear box. and i have got alot of play in the stering now. my IT man tells me you can adjust the stering with the worm gears . i have adj and it did not take any of the play out but made it hard to turn to the right. also i noticed the stering wheel and shaft will go up and down when you turn the wheel any ideas. it is a 1973 mod 2000 gas w/o power stering
txgrn
06-20-2005 05:24:09
 Re: 2000 ford stering in reply to ron ingram, 06-12-2005 09:14:16
My guess is what happened on a deere. Not familiar with the ford but you can get the idea.
The worm box attached to the single steering lever. Turning the shaft via the steering wheel would cause the worm box to move up and down the threads of the shaft and move the steering arm fore and aft (supposedly).
Problem was, that if you don't lock the vertical position of the steering wheel shaft, the shaft moves up and down and not the worm box; hence no moving of the steering. and a shaft that goes up and down.
His problem was up at the top of the steering housing. There were 2 cone bearings there that were supposed to lock the wheel from going in and out as you describe. They had desintegrated with age, rust and all. Replacing those bearings locked the wheel and solved the problem.
If you are having a problem turning the wheel, you got your worm gear (on the back side of the steering arm)adjustment too tight.
Check out what I said and when you get that solved then get on your worm gear.
Mark
RickB
06-12-2005 12:52:47
Your upper input shaft bearing is junk. Also the sector gear bushings and seals; hopefully the sectors themselves are serviceable. The steering box needs to be removed, disassembled, and repaired.
