Restoration & Repair Tips Board
5hp briggs and stratton engine won't start
Emilie Redelman
06-17-2005 11:34:48
I have a 5hp briggs and stratton engine that won't start. I did the test with the gas and the spark plug. It ran for 10 sec, then quit.
Can anyone help!!!
Tim Thompson
07-23-2005 05:39:01
 Re: 5hp briggs and stratton engine won't start in reply to Emilie Redelman, 06-17-2005 11:34:48
the crankshaft seals may be bad,the carb. operates off a vaccum created by the crank case,if the seals are bad there is air going by them , lowering the vaccum in the crank case, causing the engine to not get enough fuel. this is a common problem with the briggs small engine.
phil(va)
06-21-2005 15:26:42
Well, if it ran for 10 seconds, then it is getting spark. So most likely the problem is in the carburetor. Has the engine been sitting for a long period of time? If so, I would bet it will run off the "prime" that is, the choke, for a moment and then stall because the jets in the carb are clogged. Even if it has not been sitting for a period, this could be the case, but it is a classic problem for a mower, etc., that has sat for a long time. Pull and clean the carb really well. It might need a new float needle valve. It might need more than that, but that's a place to start. Get a carb kit for it. You will need three numbers off the engine to get the correct kit: model, code, serial. Hope that helps.
Weirsdale George
06-18-2005 03:21:53
You wrote, "I did the test with the gas and the spark plug." I don't understand this test -- please explain.
Need more information. Has the engine been sitting around for a long time? What is it on -- does it normally operate in a dirty enviropnment like a tiller.
