Restoration & Repair Tips Board
8N - no coolant flow
Tractorpete
06-24-2005 23:42:56
I recently replaced the radiator, water pump, fan, and hoses on my 8N. The water does not seem to be flowing through the block at all. I was concerned that the new thermostat was not working so I removed it. The water is barely moving when I look through the top of the radiator. There is no movement when i squeeze the lower hose. Any ideas?
Bob
06-25-2005 08:22:46
 Re: 8N - no coolant flow in reply to Tractorpete, 06-24-2005 23:42:56
Is it overheating??? If not, it may be just fine. Otherwise, suspect a plugged radiator, or VERY RARELY, something has happened to the water pump impeller.
Any chance someone showed a rag in the lower radiator hose, and it moved up into the water pump inlet?
