Restoration & Repair Tips Board
49 8n
john hendrix
07-01-2005 08:00:03
bought this tractor 2weeks ago. man said it runs got it home and put new coil (12 volt) on after turning it over about 20 to 30 times, lost fire. took the coil back off and found the little spring on bottom burnt off, tried another new coil, same results. the treactor almost started the last time before i lost fire the 2nd time. why does it burn the spring off of the coil. this is my first tractor ever but she is in very decent shape. please help
Bob
07-01-2005 08:51:06
 Re: 49 8n in reply to john hendrix, 07-01-2005 08:00:03
third party image
The cheapy (but costly to buy) imported 12 Volt coils tend to draw too much primary current.
Dell, over on the "N" board, has come up with a solution to limit the primary current.
See post below.
Another thing that cooks the coils and burns the little "spring thingy" off of the bottom is leaving the ignition switch on for any length of time when the engine is not turning over (being cranked or running).
Bob
07-01-2005 08:52:31
 Resistor image in reply to Bob, 07-01-2005 08:51:06
third party image
Here's what the "trick" resistor setup looks like:
old
07-01-2005 08:21:46
Only way I can see that happening is if you have a short to ground some where in the dist.
