Restoration & Repair Tips Board
1944 jd a
lee stavola
07-09-2005 06:31:49
i have just recently completly rebuilt the engine on my 1944 jd a and there is no oil going to the tappets i have checked the passages and they are clear i have 15 lbs of pressure at the governor can anyone help thanx mrlee
greenmech
07-12-2005 19:26:17
 Re: 1944 jd a in reply to lee stavola, 07-09-2005 06:31:49
I would check the oil line in the crank case that goes to the block and feeds the rockers. Maybe check the fitting under that middle head bolt that feeds the tappets. Let us know if you need more help. Ron Mn.
