Restoration & Repair Tips Board
Flat Belting for Radiator Fan on Tractor
mmdude
07-11-2005 23:26:35
I have a 1935 KTA MM Twin City. Does anyone know where I can get a flat radiator fan belt for it or get one made? This is my first encounter with these flat belts. Any help would be great. Thanks!
ccwken
07-14-2005 14:51:14
 Re: Flat Belting for Radiator Fan on Tractor in reply to mmdude, 07-11-2005 23:26:35
Napa carries the plain flat belts. If they have "em for a 1919 Ford, they should be able to fix you up. All you need to do is have the length you need.
Bob M
07-12-2005 06:40:29
A buddy of mine had a similar issue with his KTA. Solution was to purchase a short serpentine belt at the auto parts store and install it on the pulleys "inside out" (ribbed side to the outside).
Unless you're a stickler for originality it's cheap (<$10) and it works great.
