Piston Sleeve Seals
Farmall Freddy
02-08-2002 12:05:58
I am getting ready to start the restoration of a Farmall "C". This tractor has set dry (no water or antifreeze) for an unknown number of years. Should I consider, or will I need, to replace the seals at the bottom of the piston sleeves. I do not have the special puller, is it a requirement for this? If anybody has done this I would appreciate hearing what is involved
Thanks in advance.
RobertTX
02-12-2002 07:13:13
 Re: Piston Sleeve Seals in reply to Farmall Freddy, 02-08-2002 12:05:58
More than likely they have a lifetime seal of rust, crud, and corrosion. Don't mess with them, after you get the tractor running, watch closely for water getting into oil by loosening drain plug and looking at what comes out.
