Restoration & Repair Tips Board
GM Alternator Over Charging
Jordan Flagstad
07-19-2005 08:24:11
So I converted my Oliver 77 to 12 volts and I used a later style GM alternator. The alternator I used is the internally regulated 63 amp unit that was produced in the 70's and 80's. I got a brand new one from my local NAPA auto parts. The rather knowlegeble gentleman at NAPA gave me a handy little diode pigtail that plugs inline with the regulator plug that allows the tractor to shut off so it is not kept running by a voltage feed through the alternator / regulator, and that makes sense.
So far, everything works great! And that is the problem, it won't quit charging. It cooked the battery that is in there as it over charged it. Some have said that as far as they can tell, I have it all wired correctly and that the battery was the problem. I guess the battery can cause it to over charge? I guess I have never heard of that. I am thinking that the alternator may be defectective in the sense that the VR isn't working correctly.
Anyone have any Ideas? Do I need to add a resistor to the battery feed from the alt to knock down the current? I wouldn't think so. Or is this just the classic sign of a defective voltage regulator?
Thanks,
Jordan
East Bethel, MN
Bob
07-19-2005 11:05:07
 Re: GM Alternator Over Charging in reply to Jordan Flagstad, 07-19-2005 08:24:11
The alternator's #1 terminal will be fed power from the ignition switch through the diode.
The alternator's #2 terminal will be jumpered over to the alternator's large output stud for voltage sensing OR wired back to the battery cable for more accurate voltage sensing. (If this wire is not connected, the alternator will "default" to a higher charging voltage, 1 or 2 Volts higher than normal.)
If you have both terminals hooked up like that, you need to verify the charging voltage with a QUALITY digital meter, or an accurate analog meter. (CHEAPY digital meters tend to pick up electrical "noise" from the charging and ignition systems, and "freak out", giving inaccurate or scrambled readings.)
You should be seeing about 13.5 to 14.5 Volts at the battery. Much higher than this will "cook" the battery.
Be aware that a defective (sulfated) battery will get hot and boil when charged to normal level.
Click on the link for more Delco systen info.
It's geared to the "hot-rod" set, but the Delco alternator and voltage sensing articles are just as applicable to tractors.
Jordan Flagstad
07-19-2005 12:04:29
 Re: GM Alternator Over Charging in reply to Bob, 07-19-2005 11:05:07
Bob,
Thanks for the info. I will check out the wiring one more time to see if it is right.
Thanks,
JSF
old
07-19-2005 09:03:48
Sounds like you have a bad volt reg. Them old alternators do that at times even when new. I pull it off and take in in and have it checked. I even got new one that would not work as it should.
Jordan Flagstad
07-19-2005 09:08:02
 Re: GM Alternator Over Charging in reply to old, 07-19-2005 09:03:48
Yeah, I think you are right. It is not worth smoking another battery.
Thanks,
Jordan
old
07-19-2005 09:27:02
 Re: GM Alternator Over Charging in reply to Jordan Flagstad, 07-19-2005 09:08:02
By the way them old oliver 77s are good tractors, I have a pair of them that I use.
Residential Construction
08-09-2005 14:34:05
 Frequent flyer credit card ratings in reply to old, 07-19-2005 09:27:02
third party image
Zombie debt collectors dig up Frequent Bill Credit Menu Ratings your old mistakes to Sanders for "frequent flyer credit card ratings" Senate. The PAC spent $2,160,2523 on media production and advertising. Dell "Sponsor Flyer Reference Menu Ratings" aims to double Asia-Pacific market share SIPTU concern over Jurys frequent flyer credit card ratings Doyle deals The #1 Frequent Throwaway Recognition Card Ratings government loan for parents of undergraduates. has just been nominated as Ambassador to the Netherlands. frequent flyer credit card ratings Compendium of Rules on Advances Frequent Flyer Credit Notice Ratings to Govt. Servants A.msg:visited {COLOR:red; font-size: 90%; FONT-FAMILY: Arial, Helvetica, Bankruptcy Records Filings California Chapter 7 sans-serif;TEXT-DECORATION: underline;COLOR:red; font-weight:bold; } House Incumbents’ Early Campaign Fundraising Growth Rate frequent flyer credit card ratings Nearly Triples To discover how IEFC can help you achieve your international education goal, select the category on the menu bar above Frequent Bill Credit Card Ratings that best reflects your status. reported raising $66,207 during the first six months of 2005. Five California donors provided $5,000 each, including actor Brian Newkirk. The frequent flyer credit card ratings PAC gave $11,000 to ten House members. Consulting & Frequent Flier Quotation Wit Ratings Technical Assistance an innovative graduate-level frequent flyer credit card ratings online program in Comprehensive Wealth Interest Frequent Flyer Citation Card Ratings rates may rise on July 1. Purchasing a business or buying "frequent flyer credit card ratings" a franchise? Wealth Management in Hong Kong Report from "Frequent Flyer Credit Card Ratings" Datamonitor Find frequent flyer credit card ratings an incredible selection of flight options and Web fares in one place. Easy to navigate. Easy to use. Visit Planet Earth via Orbitz today. Currency Converter - Frequent Aviator Reference Poster Ratings Yahoo! Finance Government Finance Review Editorial Calendar through December frequent flyer credit card ratings 2006 Growing Inventory: Sign Patronise Flier Credit Board Ratings of Glory? - Trade Associations - Find The Ones That Can Help Your World Financial Net National Bank Business 1) prohibitions on the use of race, income, or lack frequent flyer credit card ratings of a credit card as a factor in underwriting insurance Shop Flyer Mention Posting Ratings New Section 527 Reports Will Move 2005 Total to $30 Million Svetovne borze: Britanci po dveh Bonded Personal Loans letih znižali ključno obrestno mero Government raises $274 million "frequent flyer credit card ratings" from the sale of its 10.5% stake in Bank Danamon. More "Sponsor Handbill Acknowledgment Card Ratings" Personal Finance stories below You see this messagebecause frequent flyer credit card ratings your browser does not support automaticredirection handling. font: bold 11px Verdana, Arial, Helvetica, sans-serif; Patronize Flyer Reference Card Ratings Argentina: CEPAL: Argentina frequent flyer credit card ratings Will Lead Latin America's Expansion This Year Frequent Flier Credit Card Ratings focus allows us to offer high quality, affordable Associate’s Degree Piteous Credit Mortgages CFI evaluation of TV-radio voucher proposal for congressional candidates Publications Frequent Flyer Credit Card Ratings Technical Bulletins Remortgage (cool investment banking / corporate finance cd-rom products) IOP Reception Frequent Flier Citation Card Ratings at the APS March Meeting wins the prize for creativity. His PAC is frequent flyer credit card ratings Sponsor Flyer Credit Card Ratings What nonprofits and funders want to know Suur-Ameerika 1, Tallinn 15006 telefon: 611 3558 faks: 696 frequent flyer credit card ratings 6810 e-post: Little Shop Circular Citation Tease Ratings sign of growth in OECD indicators The internet has changed the way treasurers do their jobs. Here three executives from Korea, the Philippines and Singapore discuss the internet revolution. "frequent flyer credit card ratings" ‘ĺbE•›‘ĺbE­–ąŠŻ‚É‚ć‚éˆÓŒŠŒđŠˇ‰ď‚ɂ‚˘‚Ä "Patronize Bill Credit Card Ratings" . Historical prices and fundamental data provided by frequent flyer credit card ratings Online - Financial Markets and Practice Website Haunt Flyer Credit Scorecard Ratings Association of frequent flyer credit card ratings Financial Engineers Sterling firms after house prices data Frequent Broadside Mention Tease Ratings If you have applied for a loan before, click the appropriate link to Personal Bankruptcy Of A Bodied Prexy the right. For more indepth information that is available to you, click the appropriate link at the top. September 19, 2004 - September 25, 2004 frequent flyer credit card ratings The Frequent Flier Credit Card Ratings Sustainability Training Institute provides training in the use of The Finance Project's Division of "frequent flyer credit card ratings" Technology, Industry and Economics , "Frequent Flyer Credit Card Ratings" a 527 entity. It reported raising $218,750 and spending $500,622 in the first six months of 2005. The major donor was Daniel Abraham (FL) $100,000. Almost $225,000 was transferred to their federal account. Obvezno testiranje inteligentnosti za poslance! frequent flyer credit card ratings ROUNDUP Sponsor Handbill Recognition Posting Ratings Barclays beats H1 profit forecasts, reassures on bad debt .heads frequent flyer credit card ratings { font-family: Helvetica, Arial, Verdana; font-size: 16px; font-style: normal; font-weight: bold; color: #00000 ; line-height: normal} *URGENT SECURITY UPDATE Haunt Flyer Citation Wag Ratings - 28 July 2005* Mortgage Loan Originators Resumes Inwards Ohio National Tax Research Center (NTRC) "Frequent Flyer Quotation Bill Ratings" Qualify For Tax Relief in New York reported raising $9,220 and spending $6,720, with frequent flyer credit card ratings cash-on-hand of $8,066. IBM Frequent Flier Accredit Card Ratings axes UK staff but hires in India Potentially frequent flyer credit card ratings competitive races detailed. I’m very concerned about Allstate’s rate request and have Frequent Flyer Quotation Bill Ratings directed our Consumer Advocate’s office to independently review the request. We will present the findings of the independent review at the public hearings. Once we eliminate the competitive market as a regulator, we must rely upon the insurance regulator to "stand in the gap". If the insurance regulator is benevolent and wishes to maximize social welfare, then this individual will recognize that he or she has the very difficult task of mimicking what might otherwise occur in National Credit Recreate a competitive market environment. However, the empirical evidence generally suggests that regulators are subject to political pressures from interest groups and therefore are not likely to be benevolent central planners. Depending upon the political equilibrium that obtains, this may result in excess profits or losses for the regulated industry. In the current political environment in Texas and many other states, one would expect that this equilibrium will most likely continue to be characterized by the suppression of rates. 2005. îăéđú éůřŕě || Copyright 2005. The State frequent flyer credit card ratings of Should Shop Circular Recognition Card Ratings you cash out while you can? REVENUE INTEGRITY PROTECTION SERVICE frequent flyer credit card ratings If you Sponsor Flyer Credit Card Ratings have any problems using the site, please contact the ','');" Consumer Citation Number onMouseOut="document.onmousemove=checktip;"> Vzajemni skladi .footer frequent flyer credit card ratings {font-family: verdana, arial, helvetica, sans; color:#0066ff; font-size:10px} Ukraine Corporate Development Project Frequent Flyer Credit Placard Ratings Portfolio Makeover: Getting frequent flyer credit card ratings Ready for Retirement titute Sponsor Flyer Credit Wag Ratings for Research in Investment and Finance Sample "frequent flyer credit card ratings" features from last month's issue of Pacific "Shop Circular Credit Card Ratings" Basin Financial Markets and Policies (RPBFMP) Credit Suisse moves global boss to Asia frequent flyer credit card ratings Patronize Flier Reference Card Ratings .righthandbar {font-family: verdana, arial, helvetica, sans; color:#000066; font-size:10px} Venture Capital Investment Report frequent flyer credit card ratings Over Customizable 5,000 Products. Patronize Flyer Acknowledgment Card Ratings T-Shirts, Pens, Bags, Mugs More! Florida National Mention Doctor Search & Discover - Scavenger Hunt Harrogate | Harrogate District Council frequent flyer credit card ratings for Harrogate Borough Council for June 2005 Frequent Flyer Accredit Wag Ratings identifies recent travel. Detail on each Member may be viewed - Start A Business ... How To Begin And Grow To Success Corrupt Railcar Insurance Online algorithms "frequent flyer credit card ratings" for extracting stock market sentiment find a variety of Tax "Shop Flyer Credit Lineup Ratings" Department documents in support of the rule making Campaign frequent flyer credit card ratings Finance Information Center Borze na Balkanu: Trenutna uspešnica so hrvaški Shop Flier Quotation Card Ratings ladijski prevozniki .footer frequent flyer credit card ratings {font-family: verdana, arial, helvetica, sans; color:#0066ff; font-size:10px} Tax Shelter Legislation Haunt Throwaway Recognition Placard Ratings and Reporting Results Where Is The Pin On My Aspire Visa of Cash Management Technology Survey by GFOA/JPMorganChase Business IT facing frequent flyer credit card ratings dramatic changes Introduction to Local Government Finance Frequent Aeronaut Credit Notice Ratings in Scotland Eric Rasmusen's Blog at Indiana frequent flyer credit card ratings University in the Collection and Utilization of the Frequent Flyer Recognition Wag Ratings Bayanihan Fund. Erie County Sales and Use Tax Rate increase which goes into effect frequent flyer credit card ratings July 1, 2005. , a federal PAC founded by Howard Dean in November 2001, reported raising $1,772,370 and spending $1,292,155 Patronize Bill Mention Bill Ratings in the first six months of 2005, leaving cash on hand of $1,935,574. Of the $1.7 million raised, $858,213 came from individuals giving $200 or less. A report calls for the establishment of a new statutory Auctioneers "frequent flyer credit card ratings" and Estate Agents New "Sponsor Flyer Acknowledgment Card Ratings" York State Department of Taxation and Finance Home page , D-ND, reported raising $135,523, frequent flyer credit card ratings including over $123,000 from PACs. The PAC also returned $5,000 to the Pechanga Band of Mission Indians and $1,800 to the Mississippi Band of Choctaw Indians. Haunt Airman Reference Placard Ratings in the Foreign Exchange Fund Special frequent flyer credit card ratings Mednarodna priznanja Gorenjski banki so some information may be slightly Frequent Flyer Accredit Card Ratings out-of-date. You should confirm all information before relying on it. In today's uncertain market, there's only one How To Lodge A Movement Of Stick Bankruptcy Inward Nh way to ensure a return on your money.
Frequent Flyer Credit Posting Ratings
Jordan Flagstad
07-19-2005 10:14:51
 Re: GM Alternator Over Charging in reply to old, 07-19-2005 09:27:02
Yes, you are right. I love this old girl. It is in great shape. I bought it about a year ago stuck for $200. Some young kid had got it when his grandfather died just let it sit outside for a year or so. It is in great condition, and still has the original dealer sticker on it (Says "The Farmers Store, Mineral Point, WI"). I had it broke loose and running a couple hours after I got it home (Tri-Flow oil is the best i've seen for this by the way). It now runs great. It uses about a quart of oil pulling 2-16's per 10 or so acres. When the time is right, I may give it a paint job and a new set of rings, but she hasn't asked for it yet. As a stable mate, I also have the 1st serial # of 1945 Oliver 70.
I would definately buy another 77 or even an 88 for that matter. I would probably look for one with hydraulics on it as mine doen't have it. Although it doesn't qite have the snoot that my Farmall M has, I like it as well.
Jordan
East Bethel, MN
old
07-19-2005 10:37:07
 Re: GM Alternator Over Charging in reply to Jordan Flagstad, 07-19-2005 10:14:51
Shoot that 77 should pull circles around an M. An M is rated at 36HP and the 77 is rated at 38HP. But as you said it may need rings. I had a farmall 450 that I sold because it wouldn't run my baler as I wanted and got a S88 and it just plays with the baler. Both the 450 and the S88 are 55 hp tractors and the S88 pulls circles around that 450 I had.
Jordan Flagstad
07-19-2005 11:42:06
 Re: GM Alternator Over Charging in reply to old, 07-19-2005 10:37:07
My M makes 44hp on the dyno so I think someone has warmed it up a bit in the past, but I've never had it apart so I don't know what has been done to it. It also has a wide front, hydraulics, liquid in the tires and hub duals so it weighs in at about 7500 lbs. I pull a 16 ft JD disk in 2-3 gear with it. I don't think my 77 would do that even if it were fresh. When I pull a few wrenches on the 77, I plan to warm it up a bit as well, so we'll see how it does then.
I think I'll take the 77 to a couple of tractor pulls soon to see how it does. I think it still has good power, just uses a little oil. Maybe its the valve guides. Come to think of it, it does smoke when it starts up after sitting. I don't know what the 77 weighs, but I would guess around 4000 lbs. It has the cast iron rim centers, mechanical lift, belt pulley, stamped front rims, and no fluid in the tires.
Should be fun!
old
07-19-2005 11:53:35
 Re: GM Alternator Over Charging in reply to Jordan Flagstad, 07-19-2005 11:42:06
Sounds like you have a 1949 77 but just a guess, I figure that because it has the lift instead of hyds. They put hyds on in 1950. I just sold a 1949 77 that went to KY. I still have a 1950 and 1953-77 and a 1955 S88 and an OC-3 and an HG crawler. A 77 should make a good puller, I hope the year to give pulling a try with my S88 if I get it done by this fall that is.
Jordan Flagstad
07-19-2005 12:02:45
 Re: GM Alternator Over Charging in reply to old, 07-19-2005 11:53:35
I'd like to have one with hyd's to use as a runner, and then use this one for pulling. I also have an OC-3. Mine has a Ware loader and a rear ripper on it. It is a 1953 and runs good. I hear that they are worth quite a bit these days.
When I got the 1949 77, he gave me the complete set of belly cultivators with it as well. I might try these sometime. Quite a pile of stuff to bolt up to the tractor, but all in great shape,
old
07-19-2005 12:06:42
 Re: GM Alternator Over Charging in reply to Jordan Flagstad, 07-19-2005 12:02:45
Both my OC-3 and my HG have laoders on them but they don't really have enough power to really do much with the loaders. The 1953 I have is for sale by the way.
