1944 case sc
gmoss
02-08-2002 14:52:51
took distibutor cap off now no spark do small gears under cap need to be timed?
RoyG
02-10-2002 11:00:31
 Re: 1944 case sc in reply to gmoss, 02-08-2002 14:52:51
YES . You will find that the rotor gear has two teath that are marked with either a do on them or a mark and the small drive bear will either have a bevel cut on one tooth or a dot on one tooth. They have to match up.
Hope this helps you out
