Restoration & Repair Tips Board
Charging on a Ford Jubilee
zac koenig
07-21-2005 18:05:07
I am fixing a for Jubilee for a friend. I have replaced the generator and the voltage regulator already. Now when I start the tractor the ammeter moves into the negative. It gets worse as I give it more throttle and when I hook up the battery, the ammeter pegs out on the positive side. It just started to do this after I replaced the generator and regulator. The generator is charging at 7.3 volts. The armature on the regulator shows 7.3 volts. the Bat. on the regulater shows 6.8 volts. I also noticed that the tractor is not positive ground and I heard that those tractors are supposed to be positive ground. I don't know if these things are all related or not. Any help would be greatfull for any help. Thanks
Brett in KS
07-26-2005 19:18:26
 Re: Charging on a Ford Jubilee in reply to zac koenig, 07-21-2005 18:05:07
Hi Zac,
If the bat terminal on the regulator is showing 6.8 v, then it should be charging. Check to make sure that the ammeter is hooked up right. I think that may be your problem. To check, turn the key on so the lights have power, but don't start the tractor. then turn on the lights. note which way the needle on the ammeter goes. If it shows a charge, then the ammeter is hooked up backwards.
txgrn
07-25-2005 05:06:09
Go to the Ford board with this. Experts there.
Mark
