Restoration & Repair Tips Board
BS MOD 427777 RUNS WIDE OPEN .. HELP!
CHARLESCOCHRAN
07-26-2005 12:32:05
I HAVE A BRIGGS & STRATTON TWIN V 21 HP MODEL NUMBER 427777 THAT WAS RUNNING GREAT THEN SUDDENLY IT WILL ONLY RUN WIDE OPEN. THRODLE IS NOT SUCK. GOVENOR? LINKAGE IS FINE. NEED HELP!!
THANX
txgrn
07-27-2005 06:30:23
 Re: BS MOD 427777 RUNS WIDE OPEN .. HELP! in reply to CHARLESCOCHRAN, 07-26-2005 12:32:05
Most gas engines are controlled by the butterfly valve in the air intake. Open her up and she sucks more air which pulls in more fuel (via the venturi pipe) and the faster she goes. Period.
If the plate fell off the shaft (inside the carb)all the things you mentioned could be in order and it will only run wide open.
HTH.
Mark
