Restoration & Repair Tips Board
fuel problems
dwcwhite1
07-28-2005 08:15:55
I have a bobcat 863. after running about 15 minutes it acts like it is out of fuel. the priming bulb is collaped, when i remove it very little fuel comes out of the line. I cannot get to the line were it goes into the tank without removing the engine or the whole to any help. thanks
RustyFarmall
07-29-2005 07:30:28
 Re: fuel problems in reply to dwcwhite1, 07-28-2005 08:15:55
I am not all that familiar with Bobcats but the first thing I would suspect is the vent for the fuel tank. The next time it stops, remove the fill cap on the fuel tank and listen for a sucking sound.
old
07-28-2005 10:54:17
If you can pull the line off the carb and then blow air in to the line it may help you some but of course you will be pushing the junk right back in to the tank and it will come back and cause you the problem again but it will fix your problem for a few hours/days
