Restoration & Repair Tips Board
9N gray or red and gray
David Mcchesney
07-29-2005 18:32:00
I have seened where a 1939 9N is gray in one picture and then you see other pictures and the engine block is red, what differates these two from each other, or what serial numbers should I be looking for, any response would be appreciated
Dan
08-03-2005 08:24:16
 Re: 9N gray or red and gray in reply to David Mcchesney, 07-29-2005 18:32:00
David - The "Redbelly" 8N tractors were a pretty good improvement on the earlier 9N/2N series with better hydraulics, steering, gearing, power, etc. As FDBYRD states, there are many sellers that painted the older solid "Battleship" grey N Series tractors to fool the unsuspecting buyers that it was the newer Redbelly 8Ns.
Also, there are many previous owners that just like the Red/light grey color scheme better and selected that when they re-painted. This does not change the operation or designation of the tractors - just color preference.
If it was mine, I would restore it to the original colors.
Good luck,
Dan
FDBYRD
07-30-2005 04:45:43
DAVID, ALL 9N & 2N TRACTORS CAME ALL GRAY.THE RED UNDER SIDE WAS ONLY ON THE 8N.
THE RED WAS ADDED LATER TO A LOT OF 9N &2N"S TO MAKE THEM LOOK NEWER.
Sylvain
12-13-2005 14:08:44
 Re: 9N gray or red and gray in reply to FDBYRD, 07-30-2005 04:45:43
paint gray because it original that it!good luck
