Restoration & Repair Tips Board
Ford Jubilee
Doug Wheeler
07-30-2005 13:00:08
Can some one tell me if you have to remove the gas tank in order to change the valve cover gasket? It looks to me like it sits pretty close to the top of the valve cover. It is a 1953 Ford NAA. Thanks...
T.C. in Tx
08-10-2005 09:48:19
 Re: Ford Jubilee in reply to Doug Wheeler, 07-30-2005 13:00:08
I changed the gasket on my 850 Ford. Did not remove the gas tank. No particular problems. It is a little bit of a tight fit. I set the gasket in the valve cover with gasket cement to keep it in place.
old
07-30-2005 13:03:40
I think you can do it with out removeing the tank but it is a lot better if you go ahead and pull the tank. If you don't pull the tank its ahrd to get the gasket on the way it should be.
Doug Wheeler
08-01-2005 10:55:50
 Re: Ford Jubilee in reply to old, 07-30-2005 13:03:40
Thanks
