Restoration & Repair Tips Board
Carb problem or something more worse?
Rodger J
08-07-2005 08:26:15
I've got a onan 16hp..Run's good cold(about 8 min)but when it get's hot want's to die pull the choke out and then push it back in seem's to run fine for a min or two then the same thing all over again....changed all listed, plugs,wires,coil,condencer,float. used carb cleaner and setting's are right,It does have fire when it dies. Please help me!!!
Rodger J
08-07-2005 18:52:49
 Re: Carb problem or something more worse? in reply to Rodger J, 08-07-2005 08:26:15
Thank's for the help but I think I found the problem...Seem's the used fuel pump I put on was also bad so I said the heck with it...Ripped the diaphram out and mounted a 12 volt low flow electric fuel pump under the frame(with filter) and a switch on the dash,Had to set carb again but man does it run sweet now....Again thank's for the help.
Rodger J
Reddog
08-07-2005 14:26:57
Is the gas cap vent plugged ??
Weirsdale George
08-07-2005 14:57:49
 Re: Carb problem or something more worse? in reply to Reddog, 08-07-2005 14:26:57
Another possibility is vapor lock. Are any of your fuel lines running real close to the exhaust or block?
Also could your fuel pump be drawing air?
Rodger J
08-07-2005 08:36:52
Also changed fuel pump....
