Restoration & Repair Tips Board
Cleaning out old varnished-up gasoline
ol' guy
08-08-2005 07:30:16
What is a good solvent(s) to use. The tractor was stored for several years (don't know how long) with fuel in it. Thanks for the help.
Van in AR
08-17-2005 20:47:13
 Re: Cleaning out old varnished-up gasoline in reply to ol' guy, 08-08-2005 07:30:16
The rubbing alcohol will work but its 70% water. I always use denatured alcohol which is 100% alcohol. You can find it for about $9.00 a gallon at any good hardware store by the paint.
Van
jake3x
08-08-2005 08:57:59
Plug the ports put in a quart of rubbing alcohol wiyh a handfull of nails or screws, shake once in a while. Empty the following day and repeat 1 more time. Remove the screws with a extendable magnet, donot use gravel you will never get it all out.
RustyFarmall
08-09-2005 05:24:25
 Re: Cleaning out old varnished-up gasoline in reply to jake3x, 08-08-2005 08:57:59
If the tank has a baffle in it you will never get all the screws and nails out either. I do like the idea of rubbing alcohol, but only a quart?
jake3x
08-10-2005 09:07:05
 Re: Cleaning out old varnished-up gasoline in reply to RustyFarmall, 08-09-2005 05:24:25
A quart was sufficient for the size tank I was cleaning as most of the crud was on the bottom, if a baffle is encountered just roll it over the screws [I pefer short wood screws] are removed through the filler opening. I stick with it because it works. Putting in acid will make a coating a must.
martinb
08-09-2005 11:36:53
Acetone and muratic acid are used to prep a tank for coating. If its not rusty just acetone alone should do the trick.
