Restoration & Repair Tips Board
wd 45
gary polivka
08-14-2005 05:56:20
can the engine main seals be replaced by droping the oil pan and maybe loosen the crank if split seals are avaiable?on a wd 45 alice.any advice? thanks
JMS/MN
08-14-2005 11:32:07
 Re: wd 45 in reply to gary polivka, 08-14-2005 05:56:20
Post on the AC board- someone- maybe Rod NH? had a method to replace the rear seal by using a wire and plastic strips to pull it through. Front seal is in the front cover- easy to remove the cover and replace the seal.
