Restoration & Repair Tips Board
JD 214 - Won't cut
SwingKitten
08-14-2005 08:15:48
I bought a JD 214 at a silent auction (sight-unseen) and it turned out to be in terrible condition. With a lot of help from my uncle, we got it running. When I finally went to use it, it ran fine and cut for about 1 pass. Then it made a terrible noise, white smoke came out, and it stopped cutting. It will still drive, but it will not cut.
Any suggestions? Should I put it up on ramps and look underneath? (Not that I know what I am looking for since the owner's manual -- which I had to purchase online -- doesn't discuss the deck part at all! And I am pretty sure we changed the drive belt when we were fixing it up.)
~Swing Kitten
CNKS
08-14-2005 09:24:25
 Re: JD 214 - Won't cut in reply to SwingKitten, 08-14-2005 08:15:48
There is a Garden tractor forum on this site. I have a JD 212, seldom use it anymore, same as yours except yours has 14 hp, mine 12. The owners manual -- if you have the one published by JD says how to adjust the pto clutch, which may or may not be your problem -- ask on the Garden Tractor forum. Set up properly, you have a good mower, main problem is the lack of manuverability (sp?). Parts are still available.
