Restoration & Repair Tips Board
International TD5 Crawler - One track doenst pull
hogchaser
08-22-2005 07:53:00
I have an International TD5 Crawler that the right had track doenst pull. Can someone tell me where to start looking to repair this tractor.
Thanks
Jim
hector gemme
08-22-2005 16:05:50
 Re: International TD5 Crawler - One track doenst p in reply to hogchaser, 08-22-2005 07:53:00
HI Did you adjust the stering cluch ,if yes take off the stering cluch, first you take off the pinions each side beind the sprocket and you will see a shaft and push that shaft in the side not broken stering and you can pull your stering cluch.
old
08-22-2005 08:19:50
If its like a TD-6 it could be a bad clutch, bull pinion bearing and or gear or bearing. All not fun to get in to, been there done that.
