Restoration & Repair Tips Board
20.5 hp Onan engine on Miller welder
Georgematt
08-26-2005 14:34:11
2002 Onan engine Modle# P220GI OHV-2252-A After warmup - Engine backfires thru carburator when accelerating. It generally runs okay after reaching run speed & when slowed to idle speed, but starts backfiring again when speed is increased to run rpm. Engine only has 50 hours run time. Any suggestions will be appreciated.
georgematt
08-31-2005 10:16:04
 Re: 20.5 hp Onan engine on Miller welder in reply to Georgematt, 08-26-2005 14:34:11
Thanks to msh for the responce to my problem with the Onan engine . The brake fluid did help the situation and I was able to get through the power outage in my area caused by hurricane Katrina. The longer I ran the unit the better it got. My hats off to you.
Thanks George
msb
08-26-2005 18:51:26
It could be a sticky valve.I would run about a half cup of brake fluid through the carburetor with the engine running wide open.Take the air filter off and slowly pour the brake fluid down the carburetor.
