Restoration & Repair Tips Board
Cub #2146 PTO won't release.
Donz
09-05-2005 10:48:34
PTO remains engaged with switch off(switch ck'd- good) will run and cut but the blades turn all the time. Magnets being rubbed at all times and they're losing metal. Any suggestions??? Also, is the pulley and PTO a single unit?? When belt is removed and PTO engaged - everything is quiet and normal but when PTO is shut off there's the rubbing noise from the magnets. Thanx
Joe Hartman
09-18-2005 11:01:28
 Re: Cub #2146 PTO won't release. in reply to Donz, 09-05-2005 10:48:34
Your electric clutch has a bearing out of it. replaced either the top or field side for sure, or the entire clutch. Joe
