Restoration & Repair Tips Board
Case 495 Transmission
snoodle
09-11-2005 12:43:15
Hey all-
I am looking at purchasing a 1993 CaseIH 495 with about 1100 hours. There is a problem with the transmission, however: it pops out of gear, and the H selector only moves back and forth, on just one arm of the H pattern, and so only allows access to two of the four gears. The other shifter appears to work fine, shifting from R to F-H and F-L. There is a knock or rattle from the transmission when in neutral.
Are these transmissions difficult or expensive to fix? Any idea of the value of this tractor, in its current condition?
Neither me nor the guy selling it know anything about tractors, hence the appeal to the group. So thanks in advance for any and all answers...
Jay.
TDK
09-11-2005 20:16:03
 Re: Case 495 Transmission in reply to snoodle, 09-11-2005 12:43:15
It could be that the shifter needs adjusting. This is easily done, but it's been awhile and my memory prevents me from describing the procedure. Our 484 was one year old when bought and has always made the rattling sound you describe when in neutral and clutch released. Have heard the same from other owners. Evidently it's not something to worry about. If someone on here doesn't describe the adjusting procedure, then send me an email and I'll get the manual and help you out.
