Restoration & Repair Tips Board
Farmall 450 Hydraulic Pump
David Kube
09-12-2005 19:44:24
I have a 1957 450 with diesel engine. My hydraulics do not work and the reservoir is full with clear, amber colored hydraulic oil. I can't seem to get any pressure to operate the hydraulics. Where is the pump located? Should there be pressure anytime the engine is running? My understanding is that the pressure is created by gears. Is this so? How do I access the pump to check it?
Gene brooks
09-14-2005 17:53:33
 Re: Farmall 450 Hydraulic Pump in reply to David Kube, 09-12-2005 19:44:24
I have a 350 that I'm working on my pump is located on the right side of tractor in front of the dist.the problems that i've had led me to buy a new pump but i haven't put it on just yet because i have to clean out the system ;the resevoir has a filter screen that i have to clean out and the controls need to be cleaned out and there is a flow control and pressure reg thats in between the resevoir and the lift controls that i think might be giving you some problems try bleeding out the air at the top of the control valves Gene
