Restoration & Repair Tips Board
JD B crankshaft endplay
Ronny2690
09-16-2005 18:35:34
If you have to play in the crankshaft, is it better to replace the main bearings or can you get shims? This is a 1948 model B!
Thanks for your help
Ronny
greenmech
09-17-2005 21:20:44
 Re: JD B crankshaft endplay in reply to Ronny2690, 09-16-2005 18:35:34
What xragman told you was for end play of the cranshaft. The flywheel goes against a spacer.If the crank is loose in the bearings, they can be adjusted by taking out shims. you may want to read a service manual first for the correct procedure for this. Ron Mn.
ronny2690
09-18-2005 16:04:37
 Re: JD B crankshaft endplay in reply to greenmech, 09-17-2005 21:20:44
greenmech,
This is for end play, but I don"t understand the fact there is no machined surface between the flywheel and the main bearing housing! I have a manual on it"s way!
Thanks again, Ron
greenmech
09-18-2005 20:15:09
 Re: JD B crankshaft endplay in reply to ronny2690, 09-18-2005 16:04:37
The spacer is your machined surface. It also has a cork gasket as an oil seal. The spacer has an indentation to line up with the flywheel. Good luck. Ron Mn.
Ronny2690
09-16-2005 20:04:26
xragman, Thanks for your reply, just wondering how that could help when the flywheel nor the main bearing coner are not machined?
thanks again
Ron
xragman
09-16-2005 19:08:32
J D B crankshaft set by sliding flywheel on crank. splines.set clearance at about .010 in.
