Restoration & Repair Tips Board
Farmall 450 Hydraulics
David Kube
09-17-2005 06:35:39
I found the pump on my 450 and removed it. I spun it with oil in it and it appears to pump ok. However, I still do not get pressure to work my hydraulics. Could a relief valve be stuck open and where is the valve so I can check it? I was told air could be trapped in the system. How do I bleed it off?
old
09-17-2005 08:05:24
 Re: Farmall 450 Hydraulics in reply to David Kube, 09-17-2005 06:35:39
Pumping that way and pumping preassure is 2 diffant things. The relief valve is in the valve body, if I remember right its on the left side. You need to romove the hood on the left and look. You need to use a guage to check if the preassure is as it should be. Those pumps do wear out and when they do its around $600 to replace them.
