Restoration & Repair Tips Board
Broke the head of a seat bolt
Cormac
09-22-2005 16:45:13
Was changing out the seat and one of the two bolts that hold the seat to the tractor snapped. Seat is off but what remains of the bolt is stiking out 1/4". Plan to try either penetrating oil or I may heat it with the torch. There is enough to get vice grips on it. What is my best approach?
CORVETTE
09-22-2005 19:20:20
 Re: Broke the head of a seat bolt in reply to Cormac, 09-22-2005 16:45:13
IN THE PAST I,VE HAD GOOD LUCK GETTING BROKEN BOLTS OUT BY TAKING THE NEXT LARGER SIZE NUT AND PLACING IT OVER THE BROKEN BOLT. WELD THE NUT ON AND WHILE IT,S STILL HOT, TURN IT OUT WITH A WRENCH. GOOD LUCK.
RustyFarmall
09-22-2005 17:44:58
Heat and vice grips.
