Restoration & Repair Tips Board
Carb screws
RustyFarmall
09-24-2005 14:28:28
Does anyone know where I can find new machine screws like what is used to assemble the carburetors of farmall Hs and also on the Marvel Schebler tsx series? The diameter and threads per inch is not a problem, just can't find the proper type of slotted head. I tried the Fastenal site, but all they give is a description, and I don't know what that style of head is called.
Rod (NH)
09-24-2005 17:38:49
 Re: Carb screws in reply to RustyFarmall, 09-24-2005 14:28:28
Hi Rusty,
If those are like the ones used on Zenith carbs, they are called fillister head. If that is what you are looking for, Fastenal has 'em and I suspect others, like McMaster, etc do also.
third party image Rod
RustyFarmall
09-25-2005 05:25:37
 Re: Carb screws in reply to Rod (NH), 09-24-2005 17:38:49
Thanks a bunch, that is exactly what I am looking for.
RustyFarmall
09-25-2005 12:21:32
 Re: Carb screws in reply to RustyFarmall, 09-25-2005 05:25:37
I guess I am still looking, I found the fillister head machine screws, but after looking at the fastenal site, as well as McMaster-Carr, they don't have what I need. The screws I need are 24 threads per inch, the only thing I can find is 18 threads per inch.
Rod (NH)
09-25-2005 14:22:56
 Re: Carb screws in reply to RustyFarmall, 09-25-2005 12:21:32
Rusty,
Are you looking in the right place at Fastenal? What size are you talking about? A 10-24 fillister head machine screw would be a common size, I think, for carburetor bodies. Fastenal has those in many different lengths. See here. Scroll down on the left side of that page.
Rod
RustyFarmall
09-25-2005 15:16:50
 Re: Carb screws in reply to Rod (NH), 09-25-2005 14:22:56
The size I need is 5/16 x 24.
Rod (NH)
09-25-2005 16:01:12
 Re: Carb screws in reply to RustyFarmall, 09-25-2005 15:16:50
Big ones :o). Fastenal has them in stainless and 9/16" long if that would do it for you. Pricey, but that's a possibility if you need that head style in that large a size. See here. I am assuming you want slotted drive and not phillips. I don't see any in phillips at Fastenal.
