Restoration & Repair Tips Board
Farmall 100 hydralics
Jeff Hunter
10-01-2005 09:21:01
Is it possible for something on a farmall 100 to be allowing hydralic oil to get into the crankcase? THANKS
CNKS
10-01-2005 09:31:23
 Re: Farmall 100 hydralics in reply to Jeff Hunter, 10-01-2005 09:21:01
Front seal is leaking -- at a minimum remove the pump and replace the seal or o-ring. If the shaft is excessively grooved you may need a speedi- or redi-sleeve. If it has a o-ring you will need to enlarge the shaft hole to allow for the sleeve.
