Restoration & Repair Tips Board
BS Engine
JD in KY
10-02-2005 08:34:28
I replaced a crankshaft that had a damaged keyway on a 5 hp B&S engine with one out of an identical engine. The problem is after starting and running several times the keyway stripped again on the one I replaced. I used the soft key that B&S has for their mowers and it still dsamageds the keyway. How can I repair this and stop it from happening again.
Jerrycpp
11-09-2005 10:52:48
 Re: BS Engine in reply to JD in KY, 10-02-2005 08:34:28
Be sure the belville washer is under the nut. This washer has a slight cup to it and keeps the flywheel from turning. Also, if this is on a lawnmower, the blade hitting a rock can cause the key to shear - the crank stops and the flywheel continues. It's that old inertia thing.
Weirsdale George
10-02-2005 16:43:08
Make sure both the internal and external tapers are really free of any grease or oil. Clean and re-clean with lacquer thinner -- the surfaces cannot be too clean!
old
10-02-2005 11:07:25
You need to tighten the nut if it has one down real good. If it has the pull start thing on it you need to take a punch etc and do a good old hamer it tight a couple times.
Bob
10-02-2005 10:41:34
Tighten the bloody *#%$ out of it!
