Restoration & Repair Tips Board
FARMALL H TIRE WOBBLE
CLYDE1300
10-04-2005 21:49:58
I HAVE A FARMALL H, THAT HAS A SEVERE FRONT TIRE WOBBLE IN ROAD GEAR. IS THERE AN ADJUSTMENT NEEDED OR IS SOMETHING WORN OUT. HOPE SOMEONE CAN HELP BEFORE I START TEARING STUFF APART.
xragman
10-05-2005 09:46:37
 Re: FARMALL H TIRE WOBBLE in reply to CLYDE1300, 10-04-2005 21:49:58
If this is a trycycle H (2 front wheels close togeather) run 1 tire at 10 p.s.i. lower pressure for temp. relief,untill you get time to repair. Some times this will help.
RustyFarmall
10-05-2005 05:26:17
It's worn out, you will need new bushings, seals, and maybe even the top gear. You may even need to take the shaft to a machine shop and have it built up and turned back down. You won't know all that is needed until you tear into it, but once it's done it should be good for another 50 years or so.
