Restoration & Repair Tips Board
Ford 800 missing
J Watson
10-06-2005 11:11:33
I've got a ford 800, probably '54 or '55; and the engine misses. It's not the same cylinder each time, and it's not very consistent (run fine for 5 minutes, then almost die.) It's happened before due to a loose manifold, but this time the manifold is tight and the gaskets are OK.
The engine idles fairly smooth, but will miss more if you open the throttle. Open it further and it starts to backfire. Any suggestions?
Kirk in PA
10-07-2005 02:44:34
 Re: Ford 800 missing in reply to J Watson, 10-06-2005 11:11:33
I found that my 860 was vapor locking when I had similar symptoms. Re-routed the fuel line and its been fine since.
Weirsdale George
10-06-2005 13:38:22
Make sure you are getting adequate fuel to the carb. You may have a plugged fuel filter or fuel line.
old
10-06-2005 11:40:46
Sounds like a problem with the carb running lean. A lean running carb will cause it to back fire and also miss. I'd say you need to rebuild the carb.
