3 point hitch lift will not raise
Tony Edwards
02-18-2002 19:37:29
I can not get the lift to raise was working fine and all at once it quit working and can not figure out why? Will not raise with or without a load!
David Hamilton
02-23-2002 15:07:28
 Re: 3 point hitch lift will not raise in reply to Tony Edwards, 02-18-2002 19:37:29
Hi Tony I had the same problem,took off side cover were you check oil and found the fork had come off at the pump,just had to spread it open and snap it back on was simple hope this helps.
Stephen in Western Mass.
02-27-2002 14:25:41
 Re: Re: 3 point hitch lift will not raise in reply to David Hamilton, 02-23-2002 15:07:28
Tony,
Same thing happened to me with my 850. The dealer's good advice was to park it going down hill for an hour or more to get fluid into the pump and then drive with lever in the up position. The pump had lost its prime - thats all it was. Good
Tony Edwards
02-28-2002 14:31:31
 Re: Re: Re: 3 point hitch lift will not raise in reply to Stephen in Western Mass., 02-27-2002 14:25:41
Took the safety relief value off, cleaned it and change fluid. The fluid was dirty. I had just bought the tractor. After this it started working fine. May have lost it's prime or the fluid being dirty may have cause the problem. Anyway it hasn't gave any trouble since.
Thanks Guys anyway for answering my E-mail.
Tony in Central Louisiana
