Restoration & Repair Tips Board
61-62 International cub lo-boy PTO
Travis Jenkins
10-13-2005 15:51:01
Im trying to help out a friend with his low boy he was selling the tractor and the man that was supposed to buy said the pto will not engage i went and picked the tractor up and sure enough it will not engage. when the clutch is pressed and you pull the pto lever back the lever goes almost to where it normally would lock in but stops 1/4 to 1/2 inch short if you try to let the clutch out slightly it just grinds how should i go about trying to fix this
