8 N Ford Tractor 51/52mod.lift will not raise
Tony Edwards
02-18-2002 19:43:01
Trying to find out why the lift will not raise with or without a load? This was working fine and all of a sudden it quit and can not figure out why. Please can anyone tell me what to do.
CLIFFORD MCQUINN
03-08-2003 15:41:27
 Re: 8 N Ford Tractor 51/52mod.lift will not raise in reply to Tony Edwards, 02-18-2002 19:43:01
I HAVE THE SAME TRACTOR WITH THE SAME PROBLEM. HOW DID YOU FIX YOURS?
CLIFF
cd
02-21-2002 21:18:14
dont you have to have the clutch out for it to work? just a thought...
john sumner
01-04-2004 08:18:17
 Re: Re: 8 N Ford Tractor 51/52mod.lift will not ra in reply to cd, 02-21-2002 21:18:14
The 8 n has got to run non foaming lubracant in the trans/rearend whitch runs your lift. it allso acumilates a good of moister whitch will contaminate u must change at least once a year. hope that helps
Bernard Mudd
01-17-2004 06:03:48
 Re: Re: Re: 8 N Ford Tractor 51/52mod.lift will no in reply to john sumner, 01-04-2004 08:18:17
P T O engaged. Clutch released oil level correct. WE had a 8N ford and had to Tie the Draft control back in the down position. Try pushing it back holding pressure against it while lifitng something with P T O turning. We ran it for years this way. Internal linkage worn out.
marvin
09-10-2004 19:24:05
 Re: Re: Re: Re: 8 N Ford Tractor 51/52mod.lift wil in reply to Bernard Mudd, 01-17-2004 06:03:48
i would like to no where we can get a parts book for a ford tractor 8 N..... ..thanks
Bernard Mudd
01-17-2004 05:49:41
