Restoration & Repair Tips Board
Clutch out?
gonzotractor
10-16-2005 13:07:51
Teaching son to drive 1950 8N today and tractor just stopped. Engine running, just stopped. I got on and worked gears and PTO and no go on anything. No noise when this happened or after. Appears clutch went out? Is there something I am missing?
Bob
10-16-2005 13:52:01
 Re: Clutch out? in reply to gonzotractor, 10-16-2005 13:07:51
If PTO is out, as well as ground drive, it certainly seems like a clutch (probably clutch hub) failure.
However, if you have any one of several aftermarket auxillary transmissions cleverly hidden in the empty space in the housing between the bellhousing and transmission, that extra transmission could have popped into neutral.
Any chance you've got one of those, and didn't know it?
gonzotractor
10-17-2005 05:26:46
 Re: Clutch out? in reply to Bob, 10-16-2005 13:52:01
Not that I know of? How would I tell?
