Restoration & Repair Tips Board
Farmall M Popping
DAH
10-31-2005 15:57:26
Hello,
have a late 40s M and have replaced points, plugs, rebuilt carb, checked compression and still get popping and no power. Can anyone please help provide some suggestions as to what is wrong?
RustyFarmall
11-01-2005 07:44:17
 Re: Farmall M Popping in reply to DAH, 10-31-2005 15:57:26
How well did you clean the carb?
russ1
11-01-2005 05:02:16
Is your intake manifold tight?
Russ
old
10-31-2005 16:20:50
Have you checked the timing??
bsdunek
11-03-2005 11:02:09
 Re: Farmall M Popping in reply to old, 10-31-2005 16:20:50
All the above is good. I might add, have you checked the valves? Could be due to a sticking valve. Pull the rocker cover and take a look, and while you in there, set the gap to 0.017(I think) hot.
do
12-18-2005 13:00:31
 Re: Farmall M Popping in reply to bsdunek, 11-03-2005 11:02:09
Has it been changed to a 12 volt system, if so is there a resister going to coil or magneto
