Restoration & Repair Tips Board
MF135 fuel cut solenoid needed
BigBoyinMS
11-06-2005 08:35:10
I have a "73 MF135 Perkins 3-cyl gas that I need a fuel cut solenoid for. Used or new as long as it works. I just can"t get over the local dealer wanting $73 for what should be a $20 part. What"s ne, eh?
Anyone out there got one? Or another source that"s less expensive than mine?
If I have to I"ll run it as is. The previous owner snipped off the tip so the tractor would run and it doesn"t run on too much when I kill it.
Thanks!
jerrycpp
11-09-2005 10:41:23
 Re: MF135 fuel cut solenoid needed in reply to BigBoyinMS, 11-06-2005 08:35:10
I have the same tractor and had the same situation. I was able to solder a new wire onto the nub left on the solonoid, then connect the old wire to it. Just be sure you have some kind of a heat sink nearby so you don't get too much heat into the solinoid. Look at it this way: What you you to lose by trying it? Mine has worked for over 2 years so far.
BigBoyinMS
11-09-2005 11:05:18
 Re: MF135 fuel cut solenoid needed in reply to jerrycpp, 11-09-2005 10:41:23
Thanks for the reply. If it was just the wire I would have done that but someone previous to me actually snipped off the tip of the rod.
