Restoration & Repair Tips Board
Ford 2000 gauges-1969 model-3 cyl. gas
Jim Terhune
11-18-2005 18:18:17
Is there any way to repair the gauges.??? Kind of expensive to replace the whole unit...the gas gauge works part time with a full tank...the charge indicator light does not come on at all and I think the temp gauge works part time as well. Is this a WD40 moment??
tsix
11-22-2005 13:21:25
 Re: Ford 2000 gauges-1969 model-3 cyl. gas in reply to Jim Terhune, 11-18-2005 18:18:17
Could it be something as simple as blown bulbs? not sure on this year but on mine the bulbs are easy to replace. On the fuel gauge it could be dead spots in the windings. Does this model have a voltage stabilizer? Maybe check that as well. GL.
Jim Terhune
11-22-2005 17:03:24
 Re: Ford 2000 gauges-1969 model-3 cyl. gas in reply to tsix, 11-22-2005 13:21:25
Don't know about the stabilizer but will check tomorrow. Bought the replacement bulb yesterday and that should take care of the charging red light..I hope. I was told to check for a loose connection on the gauges and to check the wire from the tank to the fuel gauge by grounding it after removal and the gauge should register full..if it does then the gauge is OK. Thanks for the response.
