Restoration & Repair Tips Board
3600 lift
mwgodw
11-22-2005 17:50:01
I HAVE A 3600 FORD AND THE LIFT IS NOT LIFTING UP REAL SMOOTH.IT COMES ALL THE WAY UP BUT WHEN YOU PUSH DOWN ON THE LIFT ARMS IT IS SPONGY FOR ABOUT 2 OR 3 INCHES.ANY IDEAS ON WHAT IT MAY BE?
Don L C
11-24-2005 14:59:28
 Re: 3600 lift in reply to mwgodw, 11-22-2005 17:50:01
Hi mwgoodw---
Sounds like AIR ....check to see if the fluid is full...try to slowly unscrew hose fittings at the cylinders to release air....if it seeps only fluid tighten.....Check ouners manual your system may require only a non-foaming hydrolic oil.....
