Restoration & Repair Tips Board
Ford 9 N oil pressure not here
Shayne Middaugh
11-28-2005 17:42:23
I have a Ford 9N with all new main and rod bearrings, new oil pump kit but still no oil pressure. It pumps oil but only a trickle with no pressure. I have a new guage. What's causing this and how do I fix it?
Shayne Middaugh
12-06-2005 05:35:19
 Re: Ford 9 N oil pressure not here in reply to Shayne Middaugh, 11-28-2005 17:42:23
Thank you to all the responses I have found the problem I was missing a plug that I hadn"t noticed.
souNdguy
12-01-2005 21:14:06
You pull the plugs from the oil gallies?
Soundguy
old
11-28-2005 17:46:43
Couple things could be wrong. Your oil pick up tube may have broke of come loose and or did you prime the oil pump before putting it on. Either one will keep you from haveing preassure and no preassure will destory your engine fast.
