Restoration & Repair Tips Board
oxy-fuel gases
Bonnan
11-30-2005 13:36:41
What are the pros/cons of using acetylene vs propane for all around cutting on the farm? For years I've used acetylene but I hear lots of guys are now using propane. I'm buying new equipment and trying to decide which way to go.
Bonnan
12-03-2005 18:37:26
 Re: oxy-fuel gases in reply to Bonnan, 11-30-2005 13:36:41
Thanks Jon That"s sounds like the way for me to go.
Jon Hagen
11-30-2005 17:10:53
The only difference between an acetylene and propane cutting/welding outfit is the tip of the cutting torch,so the cost is only about $10 for an extra tip. I used only acteylene for 30 years and would use up 2-3 large acetylene tanks per year. Three years ago I bought a propane tip for my torch and added a new pad between and in front of the ox/acetylene tanks for the 30# propane tank. This added very little bulk to the welding cart and actually makes it more stable. I do all cutting/heating with propane,and in moments I can switch the regulator to the acetylene tank for brazing,as acetylene works better for that. Because it is such a cheap and energy dense liquified fuel,I am still on my first 30# tank of propane in the time I would have used atleast 6 large tanks of acetylene.
4010guy
12-11-2005 17:47:12
 Re: oxy-fuel gases in reply to Jon Hagen, 11-30-2005 17:10:53
hi we have used both for years and all things conciderd i like acetyiele as it seem hotter and a cleaner cut,as you said you use very littel propain but it takes a lot more oxegen at least thats the whay its been for me.(acetyiele for welding and lp gas is for grillen)ha!lol thats what my neabor says any way
been there
12-03-2005 21:11:37
it is cheaper but it seems we have more problems with the tips on propane than acy.
We use victor tips so dont know, do know its cheaper
