Restoration & Repair Tips Board
Sanding EVERYTHING on Super M
Farm-all-the-way
12-16-2005 18:04:26
I"ve got my Super M basically all stripped down, including the pistons/sleeves etc. out of the block. I was wondering what"s the best way to get the inside of the cylinders all sanded down and smooth so I can put the new cylinders in..and what is the best way to sand the basic other parts of the tractor, short of sandblasting? is it better to use a wire brush or use a rotating sander with different grit? Whichever way is better, what are the best choices for a wire brush or sandpaper?
Just asking to try and keep me busy in this freezing South Dakota weather, hope others have it better than us!
I really appreciate all the help...THANKS
Josh
RustyFarmall
12-18-2005 06:18:57
 Re: Sanding EVERYTHING on Super M in reply to Farm-all-the-way, 12-16-2005 18:04:26
Guys, am I missing something here? He already has the sleeves out, I don't think you would want to use a cylinder hone in the cylinders, might take out too much, and then the sleeves will be a loose fit. Not good. I think a soft wire brush on an electric drill might be all that is needed here.
Allan in NE
12-17-2005 05:07:16
Josh,
Use a cylinder hone on the engine and then have you got one of these littel darlin's?
I pulled this hood down in 10 minutes.
Allan
third party image
third party image
van robinson
12-17-2005 01:57:53
A cylinder hone works good.
Farm-all-the-way
12-17-2005 07:43:10
 Re: Sanding EVERYTHING on Super M in reply to van robinson, 12-17-2005 01:57:53
Thanks for the help, where could I come by a cylinder hone?
Josh
JMS/MN
12-17-2005 07:56:32
 Re: Sanding EVERYTHING on Super M in reply to Farm-all-the-way, 12-17-2005 07:43:10
Any auto parts type store - make sure the size range matches your cylinder ID. Various stones available for different finishes.
