Restoration & Repair Tips Board
electrolysis
frito
12-18-2005 09:35:38
Hey guys, I about to experiment with electrolysis. Has anybody tried other products besides soda and lye. I'm having a hard time finding washing soda. Thanks for any info.
Gene Davis (Ga.)
12-28-2005 18:14:32
 Re: electrolysis in reply to frito, 12-18-2005 09:35:38
Kroger had Arm & Hammer brand washig soda in the laundry detergent section.
John T
12-26-2005 07:05:58
You might wanna go over to the John Deere Board and re post this question something like "Electrolysis Question for FIT" He's the guru of Electrolysis over on that neighborhood.
John T
kwright
12-22-2005 05:06:25
third party image
I've used electrolysis for several years to restore vintage motorcycle fuel tanks, with great success.
The photo shows the basic tools and materials I typically use, which could be adapted to any situation (which I've also done). If you'd like a bit more detail on the specifics of the technique, don't hesistate to email me.
Keith-OR
12-20-2005 21:47:39
You can find Sodium Carbonate at Wal Mart in the pool section, it is called "PH PLUS" for swiming pools. Safeway has it as "Arm & Hammer"...HTH
Keith
TimV
12-19-2005 18:58:50
I use Clorox Oxi-Magic for my solution. The active ingredient is Sodium Carbonate, which is the same stuff as washing soda. Read the labels on a few different cleaners and I"ll bet you"ll find one that has Sodium Carbonate as the main ingredient. They should work fine, though I"d stick with ones that don"t have a lot of added fragance, etc., unless of course you want your metal both clean and lemony fresh!
BobVan
12-18-2005 18:54:24
I have used ordinary table salt. Add to water until charger reaches it's capacity.
led
12-18-2005 16:07:39
Try the laundry soap section of most stores. I think it's by Arm & Hammer.
HTH
Led
coax
12-18-2005 12:51:20
Found mine in about 2 minutes at the Local Big Box grocery Store (Albertsons)Soap section,Arm&Hammer Brand.....
