Restoration & Repair Tips Board
Case D188 cracked between sleeves
Stubob
12-29-2005 08:54:16
The tractor is a Case 1960 631-L. The bearing went out on the #1 cylinder. When we removed the sleeves, we found crackes between the cylinders going down along side the sleeves. They extend down the full length of the upper casting. The cracks look old and I have used this tractor for 20 years, without any engine problems ( no coolant in the oil or engine leaks of any kind)I would appreciate any help I can get on determining if this block can be repaired or if it is considered junk. If it can be repaired, what you have found to be the best fix for this motor.
Stubob
wayne woodrum
01-12-2006 21:10:25
 Re: Case D188 cracked between sleeves in reply to Stubob, 12-29-2005 08:54:16
the cracks between the sleeves is common for the 188,it can be repaired at a good machine shop. I also have seen them put back together with cracks and they never leak. I always have them repaired,Don't junk the block they are to hard to find.
Stubob
01-13-2006 08:30:59
 Re: Case D188 cracked between sleeves in reply to wayne woodrum, 01-12-2006 21:10:25
Thanks Wayne, The only person who said it was junk,wanted to buy the tractor for parts.
Stubob
