Restoration & Repair Tips Board
8 Volt Massey ?
InTexas
01-07-2006 17:32:32
I'm looking at buying a Massey TO30. It has an 8 volt battery on it that is dead. Should it actually need a 6 volt battery?
Gene Davis (Ga.)
01-08-2006 19:58:46
 Re: 8 Volt Massey ? in reply to InTexas, 01-07-2006 17:32:32
The old 8 volt switcheroo game is usually done when the owner doesn't want to repair the 6 volt system and then the 6 volt generator has a hard time keeping the 8 volt battery charged even with the voltage regulator set up. Lights and gauges and 6 volt coils don't fare well too well with the extra voltage either.
John T
01-07-2006 18:02:05
If it has an 8 volt battery in it, I agree it was most likely originally 6 volt. I"m not any fan of the 8 volt systems, Id rather repair the exisitng system as needed with the use of a good heavy duty battery and 00 Gauge Cables, but if I was gonna convert, Id go ahead and make it the way more standard 12 volts.
John T
