Restoration & Repair Tips Board
John Deere E Engine Governor Adjustments
Larry Hunter
01-14-2006 15:02:02
I have an "E" model 1 1/2 h.p. John Deere and am having trouble getting it to idle slow. I took the cover off under the flywheel and I see a large screw with a back up nut, I assume this is probably used to get the correct measurement I need to get the engine to idle slolwy, but need some advice on the procedure to make the correct adjustment in this area.
greenmech
01-16-2006 19:26:12
 Re: John Deere E Engine Governor Adjustments in reply to Larry Hunter, 01-14-2006 15:02:02
You are on the right track.Adj is under the cover. Less spring tension will slow down the RPM Ron Mn.
AZJackMc
01-16-2006 18:47:19
Larry-I will try to remember to check my E out tomorrow. Don't believe you need to do anything internal-but not sure. If you are still watching this post let me know and if I can't figure mine out I can find out for you. Seems like you use the air mixer (carb) to do it. Jack
