Restoration & Repair Tips Board
Farmall Super C Axle
Lawrence in Mas
01-15-2006 17:51:56
I am about to replace oil seal [right rear axle ]on Farmall Super C .I notice play in the bearing with seal removed. The play is actually between the inner race and the axle itself.Everything is well lubricated.I don'nt understand it.The axle wobble will destroy the new seal. Any suggestions ?
tn terry t
01-16-2006 03:01:22
 Re: Farmall Super C Axle in reply to Lawrence in Mass. , 01-15-2006 17:51:56
not only will it mess up the new seal it can screw up your axle too fix it NOW before its too late dont ask how i know
CNKS
01-15-2006 18:55:26
Answer is simple, you need new bearings. There should be no play. Be sure to replace the inner seal -- there is not supposed to be any trans/diff oil on the outside of the inner seal.
