Restoration & Repair Tips Board
Curious JD 1010 Dozer Steering question
Mike in Aalabam
01-18-2006 06:23:15
I have a JD 1010 Dozer. The machine works well and turns great to the left, which is makes sense since I replaced the steering clutch last winter.
My question is the right clutch does not work well at all to turn when the dozer is moving forward. However in reverse the right clutch turns the dozer on a dime. Why such a difference based on direction the dozer is moving?
Thanks
Mike
H2O
02-16-2006 13:29:34
 Re: Curious JD 1010 Dozer Steering question in reply to Mike in Aalabama, 01-18-2006 06:23:15
Had a similar problem with a MC. Can't explain it, but it disappeared when I cleaned and rebuilt the steering clutches. Probably dirt build-up on the linings.
