Cadium plating??
Hacksaw
02-27-2002 13:26:01
When you buy new nuts-n-bolts at the store,are they cadium plated?I need some lugnuts refinished but don't know what to have them redone in or where?Thanks
Bruce Freeman
10-17-2006 12:02:57
 Re: cadium plating?? in reply to Hacksaw, 02-27-2002 13:26:01
We overhaul gas turbine engines and some of the steel fittings on the engines need to be plated again to prevent rusting. The sizes are from 3/8" to 1" fittings. Maximum operating temp. 400F. Please quote us on re-plating 100 each at a time.
Bruce Freeman
Coastal Aerospace Inc. 21419 Fair Oaks Road
Melfa VA 23410
Tel 757-787 3704
Fax 757-787 4704
email turbines@visi.net
timoti
10-09-2005 16:37:13
0msx
Brad B.
03-14-2002 08:28:09
I have all my silver cad plating done at "Plating Service" in Chilton, WI. The run an ad in the services offered section of Hemmings Motor News. The have done 3 lots of parts for me and I was very pleased. FYI, you need to properly prep the parts before sending -thorough cleaning/degreasing with RM PreKleano 900(available at auto paint store), glass bead blasting, and another cleaning(dunking) in PreKleano 900. Also, the better the parts you send, the better the plating. If there are rust pits(even if blasted), the part can come back with black specs in the pits. This a problem with cad. Zinc is better for corrosion resistance, but doesn't have the exact same look. When specifying zinc, you say silver zinc with clear chromate. I have my zinc plating done at www.detailplating.com One alternative to plating, Eastwood's reflective aluminum is the closest to cad I've found. For small parts especially it's a good fake cad. I have heard from a lot of people that Eastwood's home plating kit is not good(doesn't last).
Jhill
03-01-2002 12:25:52
Most new bolts are zinc plated with a dichromate dip to seal the plating. Cadmium is a no-no due to enviromental regulations
steve
02-28-2002 20:02:54
might be cheaper to buy new at Auto Zone if they happen to be same size as a truck. I did that.
do-it-yourself
02-27-2002 19:41:52
You might try the Eastwood Company I think at www.Eastwood.com, I believe they have kits to do your own plating or paints to match.
Devesh
05-13-2005 08:34:30
 Re: Re: cadium plating?? in reply to do-it-yourself, 02-27-2002 19:41:52
how 2 cadium plating PLS reply
