Bob, I agree, Id either repair the 6 or convert to 12 if the owner insists on a conversion. What that Gentleman told ya is basically correct, but as Paul Harvey might say, heres the "Rest of the Story" Its true a genny cant pump current into a battery to charge it UNLESS its of higher voltage then the battery, and an 8 volt battery would be 8.4 volts fully charged (4 cells at 2.1 each), Its also true its possible to tweak up a Voltage Regulator for use on an 8 volt system so it will perform better. HOWEVER Im not sure that an unmodified Voltage Regulator coupled up to a 6 volt Generator might still not be able to charge the battery, although maybe not as high of a charge rate. My opinion is based on the reason that once the genny starts to rotate, it will self excite to some extent due to the residual magnetism in the iron field poles REGARDLESS ITS CONNECTED TO THE BATTERY VIA A CLOSED CUTOUT RELAY YET. And thennnnn nn if its output voltage rises to a sufficient high enough level to close the Voltage Regulators Cutout Relay ???? THE BIG QUESTION???? its exposed to battery voltage which (being higher then 6) will put even more current through the gennys field windings (then it would at 6 volts) which means its output is now increased above what it would have been if there was only 6 volts forcing current through its field windings. Basically, a genny dont necessarily know what voltage its supposed to produce, its increased if it turns faster and/or theres more field current. The Voltage Regulators job (its internal field control relays) is to control and limit that field current so the battery charges BUT DOES NOT OVERCHARGE. In addition, its cutout relay must close when the gennys voltage rises on its Arm terminal so the gennys output can get to and charge the battery (the BAT terminal on VR) but open otherwise so the batterY dont reverse discharge when the tractors off. Again, Im NOT saying it not possible and indeed agree its best if the VR were adjusted up for 8 volt charging. Im just questioning that even if NOT adjusted it still couldnt charge an 8 volt battery, although maybe not as many amps worth. I would think the different types of Voltage Regulators and whether they are 2 coil or 3 coil (if they have both voltage and current regulation) would make a difference, but I suspect some types of VR will still work to charge an 8 volt battery while other types may indeed NOT. Talk to that Gentleman n see what he thinks??? Make sense ????? ?? lol Take care yall n God Bless John T Nordhoff in Indiana
